ignition switch on super bugs
https://forums.aussieveedubbers.com/threads/37596/ignition-switch-on-super-bugs
BiX ·
the ignition switch has fianlly given up the ghost. i have the spare one, but can't work out how to replace it. i know there is a grub screw in the barrel, but i can't find it? any ideas?
i have the wheel off, the stalks out what do i do next?
thanks
vwrallycar ·
hi Bix, now i think from memory the is a grub screw that holds it in, or it may b just a small screw. without going to have a look myself, it is tricky to work out, but keep looking.
will get back to u if ur still having trouble
Here is an exploded view of the steering...
I have sent other diagrams to Your email address.
Lee Noonan
Here is the 1971 switch..
this is NOT the same as the 1958...
that should be 1968 > 1971
Lee Noonan
Here is another selection of Ignition switches...
The key switch is seperate to the ignition electrical switch..
Lee Noonan
Here is a pic of the key cylinder....
Its all a bit confusing to Me... 🙁🙁
Lee Noonan
BiX ·
thanks for that lee, i will give it a go tomorrow!!
jakjones ·
BiX wrote:the ignition switch has fianlly given up the ghost. i have the spare one, but can't work out how to replace it. i know there is a grub screw in the barrel, but i can't find it? any ideas?
thanks
undo the 6 mm socket headed cap screw that holds the alloy housing to the column/tube , remove the housing with the key in the on position, once you have that off you will be able to see the small grub screw(use small flat blade screwdriver)
Incidently BIX, all the pics I sent to You bounced back...
Your email address doesn't work any more...
I have to do my ignition switch once I find a replacement....
BiX ·
ok after reading this last night i found a small hole on in the barrel, its between the barrel and the colum, i tried pressing this down and turing the key and pulling but i won't go.
I have also removes the cap screw, and taken the circlip out of the colum, but there is a white platic cap holding teh bearings and i assume the whole thing on to the colum?
jakjones ·
put the circlip back on you don't need to remove that,the plastic sleave just pops off ,then the housing.
Good One JakJones...
I'm glad someone knew what to do....
Bix, all the diagrams I sent, I reduced the resolution and they are the same ones posted here....
Very confusing in the Haynes manuals...
