dj_daniel88 wrote:Well, I haven't got around to checking out the heaters just yet. I am still a bit unsure to be honest. So I have to look underneath the car for the heater 'flaps'? Sorry if I am a bit thick, lol!
I'll take a couple of pics for you and post them up here - my car is a '63 model but the design is basically the same....
dj_daniel88 wrote:Also, another problem. Oil leakage! My bug has been leaving black marks along the drive away... I don't know how to fix this, but I really want it fixed. In the meantime I can't park her in the garage, coz I don't want her dripping on the driveway or garage floor. And she is cold outside!!
Hmmm, an oil dripper hey? Well, join the club - most air cooled VW's drip oil - its the way they are designed (and, no, I'm not being nasty). Most air cooled VW engines have a pipe that runs from the oil filler neck, out thorugh the tinware behind the pully, into the air - this pipe is part of the crankcase ventilation system (this was all designed and built before the rule makers decided that the crankcase ventilation system had to be fully enclosed). As the oil in the engine becomes hot, it will create a vapour in the crankcase with will rise up the filler next. As the vapour cools and condenses, it will gather on and around the opening to the vent pipe - eventually running down the pipe and onto the ground.
Of course this is not necessarily where the oil is coming from, there are plenty of seals and gaskets which can also leak oil. Can you pinpoint where most of the oil is coming from? You may need to degreses the engine, then start it and watch for leaks to be able to tell (particularly if the underneath of the engine is coated in oil).
The main areas that usually offend are the pushrod tubes (and their associated seals) and the flywheel seal....I just thought of something - are you sure that it is engine oil? The input shaft of the gearbox has a seal on it too and they can leak. The way to tell the difference is that gearbox oil has a strong smell.
Oil leaks can sometimes be difficult to track down - if you are not sure, perhaps you should talk to an experienced VW mechanic....
R
馃檪
