Aussieveedubbers 路 VW Drag Racing
Wanted: Euro '65 to '67 sedan
https://forums.aussieveedubbers.com/threads/37740/wanted-euro-65-to-67-sedan
dangerous 路
Wanted for streeter project, Euro '65 to '67 sedan, or parts. Prefer minimal rust, but no mechanicals OK. Any parts (non mechanical) of that era ....IE, big windows, wide five, balljoint,swingaxle etc. Consider anything. Good home for Pauter.
Craig Paton 路
Hi Dave
That'll be a Bloody Tuff streeter!!!!!!!!!!!!!!! 馃槈
How's your n/a drag bug coming along?
Craig
dangerous 路
Its all ready to go Craig, just need to "finance" some tyres. Boy it sounds good! Hmmm, what can I sell to buy some food?!
Craig Paton 路
Finance! I can help you in that area! Might use some equity in your home, or maybe get you into a better home loan!!!!:thumb
You'll have to let us know when your rracing your n/a drag bug!
When do you think that will be? And roughly what times are you looking for?
dangerous 路
The end of June is D-day as far as the n/a deal is concerned, Craig. Without knowing the weight, ( I would guess between 1800lbs & 1900lbs, & HP between 250 & 270.....hopefully mid elevens @ 120. I purposely want to stay in superstreet for now...thus, the steel wheels & glass windows replaced the aluminium & Lexan respectively. Oh yeah, front brakes are refitted.
Craig Paton 路
I can't wait to hear Stan's old engine with a stinger!!
Should sound nice at 8500-9000 RPM!!!!!!!!!!!!!
It will also be great to see an experienced campaigner back on the track! 馃槈
dangerous 路
Initially I want to keep the RPM down to 7000. Despite this the rest of the engine is designed to sustain 8500 if required. That means valve springs & rod bolts that are up to the job. Springs are 1.56" diameter Isky Gold stripe, & rod bolts are L19 ARP material. The ehhaust is 2" , with a short piece of 3" on the end instead of the conventional stinger...it realy sounds something else!
[Edited on 19-4-2005 by dangerous]
Craig Paton 路
Hi Dave
If I'm down your way, I'll pop in and have to hear the beast!
Cheers Craig
dangerous 路
Lunch time Saturdays is prob the best time Craig....unless I'm at the track.
