Iam new to VW engines
This is so dumb but is there a special spark spanner for beetle engines? I cannot get to mine due to the extension bar not giving enough room to turn them and the two plugs nearest me as i look at the engine are so hard to get to it seems impossible they can ever be removed without taking the engine out?
Brad ·
there are some geramn ones that work well or just buy a cheap ass tube spanner and use that.
If u can find the origional tube socket spanner that came with the car ... they work really well.
The other trick is to crack them all then get a big of rubber tube n push over the end off the plug n undo it out ...... n replace the same way ....................
battybat ·
got mine out with a cheap flexible head ratchet - one of the ones with the joint just below the ratchet head
dusto81 ·
Magnetic ones are good, cus it's a pain in the ass to drop a spark plug down onto the cylinders!
BiX ·
or if you have twin carbs cut a hole in the inner guards..............
