compression on a 1600 tp...
https://forums.aussieveedubbers.com/threads/37761/compression-on-a-1600-tp
~air fooled~ ·
what would be the deisred compression on a fresh to good engine? would you call these results poor?
these are the results of what im gettin out of my tired lookin 1600tp... i have'nt had it started yet so im not sure how it runs..
i'm gettin
engine layout...
3........1
2........4
120......100
110.......90
im thinkin if i dont have some loose head studs on the right side then i may a stuck valve maybe... wont be sure until i get it running or take the tappet cover off...
[Edited on 16/4/2005 by ~air fooled~]
Menangler ·
It would be better to run it, get it warm, then do the comp test, check valve clearances before you start it so you know they are right.
~air fooled~ ·
top idea mate! will do.... eventually!
