Guys have no idea how to take dash off including removing switches etc. Could someone please give me some tips on how to do this.
Thanks.
stephenianjames ·
Just did this today so it's fresh in my mind.
Basically, there might be some chrome trim along the bottom of the dash pad..pry this off gently with a screw driver.
Then undo all the screws along the bottom, plus the ones either side at the top of the dash (where it meets the front windscreen).
You also need to remove the two bolts which hold the handle and dash pad to the metal under-dash panel (on left hand side)
As for switches, they should all basically have plug leads which unplug...make sure you take note of where all the wires go to (should tag them all)
I think this basically covers it..anyone please feel free to add or correct me if I did it the wrong way!
[Edited on 17/4/2005 by stephenianjames]
HotRodMatt ·
have to remove the glove box to get the grab handle off.
get the guages out before removing the dash pad. reach under, squeeze the tabs at 3 and 9 o'clock and push into the cabin. easiest to start with clock - speedo - fuel.
