I have standard carbs on my 2.0l aircooled, and have just fitted tuned length "hotdog" style extractors. The car now performs better overall, but tends to be a bit uneven when accelerating through at medium revs and at about 1/4 to 1/3 or 1/2 throttle opening.
I have read about the possible need to re-jet, but when I pulled the carbs apart the only jet that I could find that was removable was the main jet (apart from the air jet at the top of the carb near the choke butterfly). Is it the main that needs to be changed ? I thought that the main was for 3/4 to full throttle range- or have I been messing about with motorbike carbs for too long ? Do extractors generally need a bigger or a smaller jet ? I've read David Schwartz's article at http://www.type2.com/ and it hasn't helped too much. There are lots of Kombis around with extractors on: do they generally need re-jetting ? Which way- richer or leaner ?
Thanks for your help.
Kom
Kommer ·
