what wires do i look for that go to the light for the dash, and if its not the connection how dou you change the bulb?
Brad ·
T2 light switch has a half sized terminal to turn / dim dash lights.
Before we go any further go and turn you lights on and then turn your head light switch around and make sure you haven't got the dimmer on. In 95% of cases they are simply dimmed and not broken. I have pulled my fair share of dashes apart only to fine the dimmer was on...
slowbay70 ·
nope not a dimmer problem, do you have to pull out the dash to change the bulb?
