Problem with Horn !!!!!!
https://forums.aussieveedubbers.com/threads/38451/problem-with-horn
vern74 ·
We have all seen it on TV and larfed but is not so funny when it happens in real life at traffic lights.........
Took Vern in for a rear wheel alignment yesterday when I went to pick him up the lady behind the counter told me that Vern was tooting his horn whenever he felt like it ! I said Oh ok ..........300 mtrs down the road at a set of traffic lights he started tooting and only stopped with the steering wheel in the "right place" Very embarrassment !
I pulled over sometime later and disconnected the horn completely as it got to the stage where it wouldn't stop tooting.
There is a bit of copper stuff sticking of the steering column that I susspect is the problem
Do I need to remove the steering wheel to fix this problem ?
Easy job ?
57kombi ·
Prise out the center section of the horn push and you can see inside and see if the wire or spring is shorting out.
Use a small flat blade screwdriver to prise the push out.
Dave
bajachris88 ·
That is hilarious. Your car wouldn't happen to be alive like Herbie?
vern74 ·
Thats exactly what the kids said .......after they got off the floor.
it would have been really funny 'cept for the dirty looks I got at the traffic lights.
I had my hands up in the air just smiling at people
I told the kids to wave ....to anybody / thing
We larfed when we got home safely in the garage
Anthiron ·
this is a problem with VW horns as they have live power all the time and go off when earthed. so if a 40 year old wire in your steering coloumn earths. your horn goes off.
vern74 ·
i kinda think I need to remove the steering wheel cause I can see some copper thing hangin out of the column
Vern
yours is a 74 right??
Yes you need to take the wheel off. It will sort of make sense then. The horn "pad" has a couple of contacts but they wont be the problem.
Use a wheel brace and take the steering wheel off. The indicator mechanism is there.
Yes there are 2 copper strips that make contact with the steering wheel. This will be where the problem is.
Worst case you will need to replace the switch mechanism.
More than likely something has got caught in the gap and pulled those copper tabs out of place
See how ya go and get back
Barry
phantom ·
I know how you feel, if my keys touch the metal sleeve around the column, they must earth the horn and it sounds.....pretty handy as the keys hang out of the ignition right beside it!
Worst if you turn right, keys lean to left and touch...argh....
Good luck.....
BLUE_62 ·
I disconnected my horn mths ago! people just watch for the finger now..... 😉
Yeah i know. I'll fix it one day. It toots unless the steering wheel is pointing straight ahead....
vern74 ·
I feel much better knowing that Vern isn't the only only one with problems in that area ! I think Bizarre is right on the money. Whitty has offered to come and take a look at it 😀 so I am sure between the 2 of us we can get it sorted ......maybe
Thanks guys
75_kombi ·
wow - im sort of glad to read this too!
i had some problems with my indicators, by the time they were fixed and the steering wheel put back on the horn sounded continuously as soon as i turned the ignition on - so i disconnected the horn at the wire bit under the front left hand side.
vern74 ·
thats how I stopped Vern making so much noise
75_kombi ·
so you gunna fix it or just leave it disconnected?
vern74 ·
Will attempt to fix it
I am sure I will need to give Mick Motors a call for parts !
remove the steering wheel and straight out the copper strip it probally bent out of shape ... it rubs on a brass ring on the under side of the steering wheel
they get bent
vern74 ·
thats the plan for Tuesday
I was glad to see that the tyre spanner can be used to remove steering wheel
The copper thing is bent and its sticking out the side
yeah thats what happens to them. straighten it with pliers and bend it so it will rub on the brass strip.
If it got a wear mark or hole you can soft solder it up to fix.
vern74 ·
Verns horn will be as good as new !
DubCrazy ·
so have u still got the horn????
steff............
