I can not get the fly wheel off
https://forums.aussieveedubbers.com/threads/38544/i-can-not-get-the-fly-wheel-off
Brett ·
I am trying to remove the fly wheel from my 1600 twin port motor. It will not budge. I have tried a rattle gun, and 3/4 drive socket set. The main problem seems to be that I can not lock the fly wheel well enought to get enough pressure on the nut.
Am I missing something. Is it a left hand thread. Any help or tips would be very much appriciated.
Brett
VolksFolks ·
HaHa, its so anoying hey, i used to struggle on and on, but i went out and got a magic tool, you can do it without any worries, its amazing how easy it is, i dont know if they are available in aussie but i got mine from overseas, check it
http://www2.cip1.com/?Click=38510
then put this part number in the search box
ACC-C10-7036
Andy
[Edited on 1/5/2005 by VolksFolks]
Brett ·
Thanks Andy, I was hopeing to not spend any more on this project. Is the gland nut left or right hand thread.
Brett
Brett ·
I got it. used some steel to wedge the fly wheel, then the 3/4 drive socket set and 3ft extension bar. Balance, hold your mouth just right and it came undone. Thankfully.
toplessbug ·
get a 3ft piece of 30x6 flat bar and drill 2 holes to match the pressure plate holes ,bolt it on then attack it with a 36mm socket and extn bar dont use the flywheel lock as you can break out the case where it bolts thru .this is the best method as you lock the flywheel directly ,and the gland nut is normal r/h thread
