i've got a standard twin carb type 4 motor except for electric fuel pump and 009 dist, and would like to know what webbers carbs would be best for a little more boost off the mark without sending my fuel bill to the moon! any ideas?
cheers josh
IDF 36 of 40's.
A set off 44's would work well to - probabally cost a bit more.
It all really depends on the vents and jets.
40's are more common but the 36's hide in Alfa / Fiat wreckers and work as well.
"IF" you were going to big valve / jug it later the 44's would be the go.
Phil74Camper ·
If you just bolt big Weber carbs on the Kombi engine with no other changes, I would doubt that you get any improvement in performance at all.
Stock Kombi Type 4 engines are detuned, low-compression versions of the Type 4 sedan engine (never sold in Australia). They are designed as commercial vehicle engines - very strong, very reliable, very low RPM engines.
They CAN give out more power and do make fabulous performance engines. The Porsche 914 uses the same basic engine, but in a highly tuned configuration with different cam, heads, inlet and exhaust and various minor parts.
You would have to do the same with the Kombi engine to see any performance gain. Big carbs by themselves - nope.
Menangler ·
Josh, Phil is right, you may get a small gain in power if you fit some twin Webers (40 or 44 IDF, don't bother with 36's they are too small for a 2ltr)
You would need to fit a fatter cam shaft and some good 1800 heads and a bit more comp, to make use of the bigger carbs. (Then go for a set if 44 IDF's)
The power gain will surprise you.
wiseoldub ·
thanks guys! just a bit of food for thought at this stage!!!!
cheers josh
Phil74Camper ·
In fact I went the other way - I enlarged my Kombi engine to 2.4 litres, but still use the stock twin carbs. All the other components - heads, carbs, exhaust etc - are still stock. The only changes I made were to enlarge the main jets and slightly reduce the air correction jets.
No more top end than stock, but put your foot down from idle and hang on! The stock carbs and manifolds pass more than enough air in the driving range I use.
wiseoldub ·
sounds really nice!!! what did you use to get to 2.4? bigger cam?what was the cost? its definately something i will wait a while to do, but i just can't seem to leave it alone! improve, improve , improve!!!!!
cheers josh
wiseoldub ·
i've also got an upright 1641 with mild cam and duel throat webber for my split and have recently been offered a set of 36' dellortos at a good price with linkages! what is better? twin carb dellortos or duel throat webber?[is it true that 36 dellortos can be re-jetted to 40'?]
cheers josh
if the dellortos are better, then my duel throat webber will be for sale with linkages for around $600.
Phil74Camper ·
To get 2.4 litres (actually its about 2.36), I used a 71mm crank from a 2-litre Kombi (which has 5mm more stroke than a 1.7 or 1.8 Kombi), and 103mm pistons and cylinders. I found mine second-hand, in never-used condition. The pistons are TRW, so I guess they were originally made for a Chevy or something.
Both the heads and case need machining to make them fit. I also modified the rods to throw oil onto the piston undersides, as these large cylinders can suffer warpage if they get hot. I also had to do a lot of checking and measuring and calculating to make sure the CR was correct (7.1:1 in my case)
I think parts and machining came to a couple of grand by the time I finished. The WHOLE engine was at least that again, maybe more. I don't like to add it all up, it gets a bit depressing!
But anyway, stock Kombi carbs are fine for Kombis. So long as they're in good condition of course. I can't help you with Dellortos - my old Beetle had twin 40IDF Webers.
One other good thing about stock Kombi carbs over aftermarket ones - once you get them set up and adjusted, you can forget them for at least 6000km. No tinkering with the mixtures, idles and linkages every weekend, like you do with Webers!
wiseoldub ·
thanks phil, good to know you are out there!!! much obliged!
cheers josh
