Wanted - late 60s, 6V Beetle pedals
https://forums.aussieveedubbers.com/threads/38630/wanted-late-60s-6v-beetle-pedals
I need a set of (I think) 66, 67 vintage pedals for my Country Buggy. There are several pedals for Beetles... I need the ones that have the pressed-steel uprights (not cast) mounted on a wide base. ie: the clutch and brake pedals have a wide gap between their bses/pivots on the shaft. The accelerator needs to be the push-rod type, not small roller. It all mounts to the floor with a flat steel reinforcing plate that angles at around 30-45 degrees towards the base of the accel pedal... I hope all this makes sense!!
Sydney if possible...
vdbleu2002 ·
yeah I got some and f'..d if I know they are the ones you need. They are off a late 60's beetle . You are welcome to come and have a look. Im in western sydney.
Yeah, I wish I had a pic so I could show what I'm looking for... but the CB pedal set is different to all the other early-60s and BJ pans around my place so I can only assume that 1) CB is same as late 60s 6V and b) late 60s 6V is different to early 60s stuff that I already have...!
bigbaja ·
i cant bloody remember what mine were like
but i thought it was only the accelorator that was different.
it came out further then straight up
terry
