I have in a couple of weeks for sale an 1800 out of our 1975 Bus. This motor is to be sold with everything attached to it as it comes out of the vehicle from Chrome exhaust tip to Flywheel and from Air cleaner box to tinware and Heat exchangers. NO Starter motor included.
The motor had bottom end full line bore etc rebuild 110,000 km's ago, and 10,000 kms ago two reco heads fitted. The Dizzy was fully rebuilt with all new baseplate and bushes a couple of years ago, and the carbies were done a few years ago. Everything works, it starts easy, idles well, carbies are in tune. Tinware has been repainted, engine bay tinware seal is 12 months old. Exhaust is German.
It does have an oil leak from the fuel pump insulator plate thing.
It goes good with no probs. It is due for 10,000 service and oil change, but I am not going to do that on an engine I am selling.
WHY? I am about to spend a ridiculous amount of money putting in a Subaru engine because I am ill. If you know me, I am never content with stock stuff and like to go to the next level.
Engine No AP048037
Price $800
Location Box Hill (Melb) - pick up only
Name Peter
PH 0403 226 999
[ Edited on 15-11-2005 by Helbus ]
beerdoc ·
Ah ha I saw this at jambaree and had forgotten about your engine
Mate of mine could be very interested if I can have first dibs and about 2 days to get back to you
beerdoc ·
Sorry to trouble you peter
We need to get a motor out of auto
free bump
[Edited on 11-5-2005 by beerdoc]
A pic of the motor!
Craig Paton ·
Craig Torrens was chasing T4 engines!
this one is to good for me...............I'm after ones that need rebuilding😉
bda55 ·
How much for motor and Transaxle?
ruckus ·
How hard would it be to convert to upright?
Andy ·
Hard? That's up to you, you can buy a complete kit which gives you everything you need to bolt straight on. Alternatively a cheaper option is to buy all the type 1 bits and adapt it on yourself, a fair bit involved this way.
Some kit's require machining the case breather off, but other than that it's just fabricating tinware to adapt the type 4 barrels to a type 1 fan housing.
There's plenty of info about if you search old posts.
:thumb
Motor is ready to go
Located in Box Hill, can be viewed during business hours. There will be limited opportunity to view ouside business hours.
U2U or ring 0403 226 999 or e-mail with an offer.
Pick up only, will not freight.
StenGuns ·
Pete.. Is this complete with Gearbox? if so I am interested..
(you mention gbox in heading but then say it is to flywheel in description)
Rob
I have added an 1800 gearbox. it is now absoloutley complete except the 4 bolts that hold the clutch pressure plate to the flywheel, and the twin carb linkage rod. The gear box was driven about 40 km by myself and felt to change gears ok, but I actually can't comment on any other qualities other than it looks like the side outputs have a bit of side movement, and it leaks a lilttle oil. I am including it as a sweetener to sell the motor.
I am unable to physically lift anything at all whatsoever at the moment, so this whole lot can only be picked up from Box Hill where I have left it. I cannot physically do anything to help ship it, who ever buys it must come and pick it up.
StenGuns ·
Thats fine.. I have a 76 dual cab coming over from SA.. It has an early 1.8L subi in it and I need to fit it back to a VW engine.. (It has NSW plates but is now out of Rego).. If your setup is as described, it will fit the bill just fine..
kombi-troppo ·
Gidday mate, do you still have this motor and box for sale?
