help to Turbo A 2lt Kombi......
https://forums.aussieveedubbers.com/threads/38686/help-to-turbo-a-2lt-kombi
import_eureka ·
Hi People,
I not long ago brought eureka with a freshly rebuit 2lt type 4 kombi (ground cam, .20 oversize pistons and so on.) which i am looking at add a turbo too.
Now what would be the best turbo to use im more after somthing to kick in about 2,200 - and go to redline which is around 5,000rpm ATM.
Also Carby best type/brand/Model carby to use ? i was thinking a lager webber or a holly.
Or another option EFI any setup i could mod.. to fit the eninge and then turbo.
Thanks for all you help
Daniel
Doug Sweetman ·
The man to talk to would be Amazer - he had had two different turbo kombi's, both of which performed very well - he knows alot about what you are planning to do.
RENNWAGEN ·
I was looking at this myself for a long time injectors, throttle bodies, turbo, programable computer, dyno time it will be cheaper, easier, more powerful and reliable to by a WRX 1/2 cut and stick it in. Sell the type 4and do some reading in the conversions forum it wont be a volkswagen any more but it isnt anyway.
import_eureka ·
Yeah thought about that but being that it is going into an eureka that weigths around 800Kg it is illigal (N.S.W) to have anything like a WRX enigne in it. I will be pushing to get this road legal
type2nut ·
There are other Subarus than a WRX.
Use a 2.2 from a liberty (130HP), a 2.5 from a Forester 160 HP) or even an older EA series engine from an 80's model Subie.
pete wood ·
import_eureka wrote:Yeah thought about that but being that it is going into an eureka that weigths around 800Kg it is illigal (N.S.W) to have anything like a WRX enigne in it. I will be pushing to get this road legal
I think you might find that the car is regoed as a beetle with a different body. So the weight of the car is based on the original weight of a beetle.
Besides you can put any motor in the car that capacity is 2.5 time the weight of the car for turbo or supercharged, ot 3 times the weight of the car for normally aspiriated.
eg. 2.5 x 800 = 2000cc,
or 3 x 800 = 2400cc
Therefore, in the eyes of the RTA, it is not about power but about capacity. A turbo kombi 2l motor is the same as a WRX motor as they are both 2l and turbocharged.
I think you'll find that you'll be able to fit the WRX motor to your car as long as the engineering signatory is happy with your brakes.
[Edited on 16/5/2005 by pete wood]
