does anybody in brisvegas have an inside bearing puller??? that i may be able to borrow or hire or steal or rent etc i need to remove a rear brg from a swinger
thanks
karmen ·
a hire shop may be able to help
but i would drop in to my / your fave mechanic would do it in a jiffy
what suburb?
Did you know these bearings were often turned back to front to run another 100Gs on the unworn side? As the angle of the swing axle caused uneven wear ??
eirecooled ·
where are you in brisbane?
and how do you get an unworn side in a caged ball bearing?
toplessbug ·
south bayside ,i can see what karmen is on about as thrust would be taken on 1 face as the pos camber angle would ensure that, just need to check that your balls are good?
