I'm after the handle for the inside of the sliding door, at the moment it only has the square centre coming through from the outside handle, which means the outside handle pulls out slightly. Can any one help?
thanks
shano
yeah i spotted that one on ebay, if they are a good price for new, then might have to buy a newy. the one on ebay is cracked, probably have the same problem in 6 months.
sent u2u to ClassicVW(pacific)
shano
nicko ·
I have one for sale, a bit grotty and a scratch or two. Make us an offer if the new ones are too expensive.
Nicko
02 65593156
11CAB ·
I had ours break, and at the time could only get a S/H one which was in a similar condition, so I made a handle out of flat steel bent so that you could get your fingers around it. I drilled a hole in it then filed it into a square to bolt onto the assembly.
Graham
KruizinKombi ·
I've been using a set of locking pliers for about 4 years. :o
