industrial motor
https://forums.aussieveedubbers.com/threads/3887/industrial-motor
wrecker67 ·
hi there i did post this under magneto down the list,but anyway got this off ebay
can anyone tell me what it was used for,and as i explained b4,the magneto has some type of electrodes one the end off the leads which seem to have screwed into a fitting on the motor where the plugs would normally go,but they are missing,can the mag be modified to suit standard plug leads,and what is the little pump thing on the motor,is running a small pulley from the crank then a belt to something that looks like a exturnal pump,but then it connects with a lever to the carby,maybe some rpm reducer.im sure someone out there can explain it to me .....cheers
aussiebug ·
It looks like it's a 1200 industrial engine.
Fired by magneto so it doesn't need an electrical system.
The "pump" you were talking about - driven from the crankshaft, is almost certainly a speed govenor - common with industrial engines to maintain a constant rpm.
They were used in pumps, generators, and air compressors (to name a few applications).
I don't have much info on magnetos, but you might find more info from
http://www.greatplanes.com/imagetime.html
The magnetos are very popular with VWs used in aviation.
speedster356 ·
I think the plugs/caps are the same as the aviation style. The sparkplug has a metal sleeve with a thread on the top.
wrecker67 ·
thanks for the info,can you still buy them
,,cheers:beer:beer
speedster356 ·
Sure can. But need to check if in fact that is the style.
Were do you live? If out near Hoxton Park Aerodrome then I can arrange for you to pick up some old ones to try if you like.
wrecker67 ·
yeh im not far from there i would be interested in getting some to try them out
also would you have some of the leeds to suit them as one of mine looks like it is missing the cover that goes over the bottom of the lead
and on the side there is a round threaded peice that puts out spark would you know where or what it connects to
cheers:beer:beer:beer
[Edited on 21-2-2003 by wrecker67]
KruizinKombi ·
I'd be interested to know how much the plugs and leads are worth please Pete. 🙂
wrecker67 ·
hi there,just say i want to run this in my bug,what would i have to do about the wiring to stop the motor still with the key,as the starter motor will still work ok..
cheers :beer
KruizinKombi ·
Convert it back to a distributor, or run an earth line through to a dashboard switch from the magneto.
You will also want to get rid of the governor - let me know if you have one for sale....
wrecker67 ·
hi there,go to your post about your magneto,david has replied about selling two magnetos and the goveners
cheers :beer:beer
KruizinKombi ·
:thumb
