What is an AS41 case
https://forums.aussieveedubbers.com/threads/38874/what-is-an-as41-case
57kombi ·
Just wondering what this means.
Is it a standard case and how do you decifer the code.
Does the 41 mean anything??
Dave
splitbusaustralia ·
From the ASM Metals Handbook, V.2, 10th edition, 1990
Room Temperature properties:
AS21
1.7% Al
0.4% Mn
1.1% Si
240 MPa Tensile Strength
130 MPa Tensile Yield Strength
130 MPa Compressive Yield Strength
AS41
4.3% Al
0.35% Mn
1.0% Si
220 MPa Tensile Strength
150 MPa Tensile Yield Strength
150 MPa Compressive Yield Strength
AS41 generally considered the 'better' case because
of the higher aluminium content (all dual relief too).
57kombi ·
Thanks Rob.
Now I know what I've got.
Dave
splitbusaustralia wrote:AS41 generally considered the 'better' case because
ummm... have i been wrong all these years :jesus
I "thought" AS21 was the high alum case
I "thought" AS 41 was the garden variety
71superbug ·
looks like you were bizarre.
1.7% for as21 and 4.3% for as41....hmm. thats gotta suck. did u buy the wrong one at anytime? HAHAH
Anthony
VWFOOL ·
how do u know which one u hav, is it stamped anywhere?
This is what i meant
"FI Beetle engines (`75 and later) don't have any provision for a mechanical fuel pump but the alloy they're made of (AS21) is better than the original AS41 and a close second IMO to the AS41 used on new cases"
http://www.shoptalkforums.com/viewtopic.php?t=77732&highlight=as21
and
http://www.shoptalkforums.com/viewtopic.php?t=79610&highlight=as21
here are some more points
http://www.shoptalkforums.com/search.php?mode=results
The first 1600 case was AS41
Then the AS 21 came out in 75 - ish but doesnt have provision for a mech fuel pump and was always considered a "better" case. It was "stronger" - i thought that meant more Al
Apparently the new cases are designated AS41 - but made of AS41A.
I dont know if there is a difference between AS41 and AS41A
What i am saying is i will bet pounds to a pig the AS41 Dave has is a garden variety AS41 from the early 70's and i would have the AS21 anyday over that
it is stamped under the pushrod tubes on one of the sides - driver i think
BajaChris ·
This is from a web page I found a while ago.
On the side of the case, you will see the letters "AS-41" or "AS-21" The AS-41 was the first ones made. In 1975 and later fuel injected engines (the ones without a fuel pump hole), the case alloy was change and the letter was AS-21. The AS-21 is better then the AS-41. BUT now VW in Brazil has changed again and went to the AS-41 again, but it is of a different alloy then the older AS-41 and AS-21 and is better than both.
It seems that the AS-21 is the better case unless you have a new brazilian case.
Click here to see the rest of the page.
koolkarmakombi ·
so that percent adds up to 5.65%
whats the rest?
BajaChris ·
magnesium
Room Temperature properties (Al=Aluminum, Mn=Magnesium, Si=Silicon):
AS21:
1.7% Al
.4% Mn
1.1% Si
AS41A:
4.3% Al
.35% Mn
1.0% Si
That is the same table as Rob's but it is AS41A - i wonder if Rob missed the A
Where is Wes when ya want him???
Wes....Wes....where are you......WES!!!
splitbusaustralia ·
sorry! - that is correct the 1990 figures are the 'late' (dual relief) AS41(A) cases!
regards
RobK
aussiebug ·
Bizarre wrote:From the ASM Metals Handbook, V.2, 10th edition, 1990
Sorry Bizarre, but you have it wrong.
Mn is Manganese (the .35% etc)
Mg is magnesium and isn't mentioned in your list, but is of course the main ingredient of the VW case, whether it's an AS21 or AS41 case.
Rob?......... Rob?????................................hmmmmmm........does any one remember Rob???
Welcome back!
Long time no hear!
Been plugging ya site while ya been busy
Welcome back!
Long time no hear!
