I have a 1970 - 1300 Beetle. On infrequent occassions for a few seconds a slight grinding - rubbing noise comes out of the fan shroud and then goes away. I have adjusted the shims (8 of them) on the Generator / Fan Belt pulley and it goes away for about a month then the noise returns.
Today, I hit a slight bump on the road, (road works), at about 30kph. A grinding noise started to come out of the shroud again - really loud. This has only happened once 12 months ago when a new belt was installed and the problem went away.
Today I put another belt on with the same recommended tension as the belt I used previously and the problem went away. However, when I slow down from revs I hear a whirring noise from the engine.
Any suggestions what the problem is and how to fix it?
John
kickatinalong ·
