hey
am just gettin myself a stereo im gonna be running 2x 12inch subs some 6 1/2's and mid bass's
anyone got any designs for a kombi where to get the best bass and beast spot etc??
rhys
Quickbug 路
Face the subs towards the rear - if you can sit them almost up against the rear of the car - firing up at about 45 degrees youll get the most bass.
What subs are they?
Are you making the box yourself?
61/2 whats? Splits? Two ways? Three ways? What brand?
What sized mid bass? What brand?
What head unit are you using? What amp/s?
DETAILS!! lol 馃榾
Woozy 路
Most important detail which will determine where you can put the sub's is how much volume do you need to use for each sub (this can be found out either in the documentation or fom the shop you bought them from.)
Sub's tend to sound best placed at the rear of kombi's perhaps sitting above the engine depending on the size of the box
vwrallycar 路
if you havent already bought the speakers and amps etc check out www.jaycar.com.au and check out their range.
i run jaycars 12" double magnet sub in their box with 4 jaycar 6" split speakers with a 5 channel amp in my falcon. to say the least its awesome.
many award have also been won with their speakers here in australia.
they also show you the design of their box
:thumb
kombi_kid 路
running a 4 channel fushion 2x 320 RMS 2x orion subs 200 RMS and planet audio 6 1/2 inch splits and the latest 4 x 50 RMS alpine headunit with subwoofer control dont know what speakers to get for the back either 2 way 6 x9" or some other splits maybe alpine?
im gettin the subs off hifidirect.com.au
rhys
Quickbug 路
6x9's and subs DO NOT MIX.
Dont even bother with them. The sub bass makes them practically pointless...
kombi_kid 路
hey
do u reacon just run some splits and midbass 8" sumthing?
rhys
krum 路
I have been toying with the Idea of building a box, or converting the small area behind the rear seat to house a Sub and a couple of speaks, Does anyone know the volume or has done this before. Its a Convertable 64-65... theres not many other options for speaker placement. any ideas would be appreciated.
Quickbug 路
Yeah stick with the splits.
As for the 8" personally id go a set of 6 - 6.5" three ways in the rear.
Midbass speakers really arent necessary with two huge subs and splits...
That would be my choice..
Krum - you can shove a 10" or 12" sealed box sub behind the rear seat in a bug. I have done this in several and it works well. It is a tight fit but most sealed mid sized boxes will fit.
Im not sure of the size of that space volumetrically though sorry.
You can make up a shelf from some MDF to house a pair or two of speakers, and to also cover the sub up a bit.
EDIT--> missed that it was a convertable.
In your case Krum would you consider making mounts to place some speakers in the doors? you are going to loose alot of sound cruising with the roof down having the speakers in the rear. The sub will be loud anyway - mine was in my convertable - but if you can - id go with speakers in the door cards, sub in the rear.
[Edited on 24-2-2003 by Quickbug]
kombi_kid 路
whats some good splits????
rhys
JOE751 路
I have got in a couple of cheepy 12" subs in the box that is under the back seat, they point forward and they do preety well for the money I paid (esp with a bit of jungle) and splits(kenwood) up front...they make heaps of difference
Oh Its a splitty 11 window.
It is interesting that Kombis (well mine) dont seem to let much bass out, unless you open the windows...I call this the"anti-wank factor"
Quickbug 路
LMAO JOE751 "anti wank factor"! Good one... 馃榾
Rhys - What kind of budget are you looking at for splits?
kombi_kid 路
hey
-$250 alpine splits are only 240 so i might give them a go!!!
got my panel all worked out everythings planned on where its got to go !!!!!
rhys
baybuscamperkid 路
on the same topic i am running a sony single disk head unit with 6x9 2way explods up front and small old pioneer? splits in the rear. sounds great and has cost me $45 total so far. wondering about fitting a pair of 6inch subs in the back without amp (i dont need it too loud, and i can by a cheap converter to hook them to). is it worth it (id only be paying $40 for a pair of old but clean subs, and maybe $30 for the converter)?
Quickbug 路
Rhys - Alpine are good, and you cant really go wrong with name brands.
If you like the sound of them and they suit your budget, go for it!!
Baybus - in all honesty 6" subs wont do much.
They are just too small!
But if you are keen then go for it.
Woozy 路
Second thing with sub's is they are a waste of time without an amp ( i've tried it 馃檪) I reckon the best way to get a bit of bass without an amp is some decent 6 x 9 's ( I know they aren't great )
Rear speakers are only for fill unless you are thinking about the passengers and then if you have decent front's it shouldnt be a problem 馃檪
With kombi's you have a volume problem (they are just too big) thats part of the reason the bass dosent 'come out' as much. You dontg have that volume problem with bugs.
Midbass is a waste of time unless you are running multiple amp's and s@#t hot other gear as they are damn expensive for even basic one's (not to be confused with 8'' subs)
My bug used to have 2 jaycar CF 10'' subs built into the back of the rear seat (that was one of my more ambitious boxes)
kombi_kid 路
hey
i will eventaully run an amp for the splits and mid bass but for know 2 subs some splits and some 6 x 9's will do!!
rhys
