Seam sealer first or primer ?
https://forums.aussieveedubbers.com/threads/39185/seam-sealer-first-or-primer
1303 ·
I have done a little work beefing up the area behind the back seat of my beetle. I removed alot of the old seam sealer so I could weld gussets and some 200mm x 200mm x 2mm shaped steel plates on each side.
Will I need to apply seam sealer prior to primer or vice versa?
I was just going to spray on etch primer after seam sealer until I get it resprayed.
Cheers Paul.
killakornkobb ·
etch prime, then seam sealer, then primer before colour... allow 25-30 mins for seam sealer to go chewy before applying 1 coat of high solid 2k primer, allow flash off, and paint colour.. no sanding of the 2k primer 🙂
