I need some help with some part numbers of a mid 70's Beetle EFI plenum and throttle body.
I am chasing the throttle liinkage parts for a good friend.
The Plenum forms the generator stand and connects to cast intake runners similar to standard ones except there are injector bosses. The throttle butterfly is on top as is the cold start enrichment injector, the aux air cold start valve is on the base of the plenum near where the fuel pump should be.
I need all the parts that connect from the throttle butterfly shaft to the accellerator cable. If someone has the whole unit for sale I would be interested in buying it. If someone has an import beetle with EFI and they could get some part numbers, and perhaps a photo it would be greatly appreciated, or even a website with the relevant info would be great.
Thanks,
Wayne
[Edited on 16/5/2005 by 1964_Notch]
koolkarmakombi ·
try the US guys,
I only know type2.com but there has to be lots others
