WTD : Oval or swingaxle type 3 torsion bars
https://forums.aussieveedubbers.com/threads/39247/wtd-oval-or-swingaxle-type-3-torsion-bars
J&SBlue ·
After a set (or even just the right hand) rear torsion bars from an Oval. These are the longer ones that look like Type 3 ones but aren't. I think there out of a 54 - 58.
New information : apparently swingaxle type3 torsion bars will also fit.
Prefer them to be in the Sydney area.
Mark.
[Edited on 17-5-2005 by J&SBlue]
J&SBlue ·
Anyone ??:duh
bigbaja ·
whats the difference with 60,s beetle
J&SBlue ·
As far as I can work out, the Oval torsion bars are longer and thicker than later model bars. However, they are not as long as Type 3 bars. I have the spring plates with the extendered "beak" to accomodate the longer bars, but one of the bars I have is very pittered. I just want to find a replacement bar, then I can put it all in.
Mark.
56astro ·
I have 2 and have marked them L and R so that they went back in on the correct side.
Not Sydney, but let me know if ya still need them.
J&SBlue ·
56astro, have sent a U2U.
dangerous ·
Swingaxle type three tortions are the same 24mm diameter and within 1mm of length. They are less likely to be pitted also. That should open up your optoins a little.
J&SBlue ·
Thanks dangerous. Didn't know there was such a thing as Swingaxle Type 3. :o
Sound like they would do the job as well.
I have a set of Late Type 3 bars if you need them
J&SBlue ·
Thanks Dave, but if they are Type 3 IRS then they are to long.
