I'm putting mine in the roof section in the rear of my bus. i had a sheet pressed up with vents to direct air into the radiator, cool air from the top of the bus as opposed to putting the radiator under the bus which draws in hot road air or having it hanging off the front of the bus which makes it look ugly and gives it away as being a converted bus from the outside all you will see it a panel welded in the roof with scoops pressed in it no too noticeable unless you look at the roof. it will be boxed in on the inside of the bus with the piping going through the air vents on the inside of the bus which aids in cooling the pipes as well. also welding in a early bay petrol cap door to fill the rad from the top
just some info on my bus it was a 4.4L v8 with 2L manual,
just changed the trans to Porsche 915
here is the panel thats getting welded in next week
the radiator is an alloy one from a 2004 v8 holden commodore "Aussie car"
and possibly the motor going in it
rammed 350 chev
[Edited on 17/5/2005 by wacked1]
wacked1 ·
