HAY GUYS JUST A FEW QUESTIONS TO ANYONE WHO KNOWS WHAT STUD PATTERN IS A 72 KOMBI ITS A 5 STUD BUT DO FALCON WHEELS FIT ALSO WONDERING HOW TO LIFT AND LOWER FRONT AND REAR OF MY 72 KOMBI BUS IM CONVERTING TO A CAMPER BUT NO POP TOP
ANY HELP WOULD BE GREAT
KEEP IT REAL EVERYONE
MUD BASHING ANYONE ?? ·
indian automotive do a adjustable front beam also ajustuble rear sping plates there number is in the vma magazine
kombibob ·
ford wheels need to be redrilled to fit but it can be done
you best bet is merc rims they are the same stud and come in 15 and 16"
the rims on this bus are merc.
modulus ·
derNeuberg_kombieKid wrote:JUST A FEW QUESTIONS TO ANYONE WHO KNOWS WHAT STUD PATTERN IS A 72 KOMBI ITS A 5 STUD BUT DO FALCON WHEELS FIT
Suggest you don't lift and lower front and rear all at once...the suspension will get confused.
HAY GUYS
Looks like your CAPS LOCK IS STUCK.
type2nut ·
You took a photo in Kimba and you didn't include the big galah?????? Man, what's wrong with you? :P
KruizinKombi ·
Kombi wheel stud PCD (Pitch Circle Diameter - the imaginary circle on which the stud holes are drilled) is 112mm vs. the Falcon PCD of 114.3mm.
My BA Falcon wheels were prepped by Ian aka Desert Bug (no, he no longer does them) to suit the kombi stud pattern. Basically he made a jig to redrill the Falcon wheels to the kombi pattern, but only remachined the chamfer, as that is where the nuts seat on the wheel, not on the studs. The holes were big enough to allow stud clearance without modification. At the time, he was also offering to change the angle of the chamfer so I could use other wheel-nuts, but I chose to stick with kombi wheel-nuts.
IF you can find someone with a suitable jig setup, there is no reason why alloy wheels can't be similarly machined. I believe 11CAB is running aftermarket Falcon alloys prepared for the kombi in this way.
[Edited on 18-5-2005 by KruizinKombi]
vwtyp2 ·
probably easier just to run mercedes rims.
that's what these were on.
VWENVY ·
Kol
That bus looks mad!!
Looks like a drag bus :thumb
wacked1 ·
kol what size are the rear tyres on your bus i must agree it looks like a drag bus.
do you think if you went any lower there would be any scrubbing issues.
ron
wacked1 ·
as the other said, you can't lift or lower the front of a bus without putting in adjusters in they have to be welded into the front beam (suspension)
the rear is easy you don't have to do any mods as long as you stay within certain limits
re wheels
you can fit mercedes, audi a4 and some others they have the same stud pattern as a kombi
here is my bus when it was raised
raised with different wheels on
and lowered
Humby ·
I have some alloys on my bus. They come from an Audi A6. The only thing I had to do was to modify the centerhole...
Here it is:
I know, my bus needs a paintjob (she gets it soon!) and lowering (but I 'll do that later, after my Suby conversion)
I didn't find some centercaps for the wheels, so I used Coca Cola cans... This looks nice I think.
Greetz,
Humby😎
field ·
where's the best spot to get a 76 bay slammed in QLD at a resonable price?
cheers.
kombibob ·
cheapest would be custom off road components at stafford bris
they do the front and rear for just under a grand i think.
give them a call 33564356
field ·
cheers kombibob:beerare u any vee dub club mate?I think i've seen u driving your kombi around the deagon area u from round that way?
field
kombibob ·
hi field im at brighton and i'm allways visiting my mate who lives at deagon
field ·
ok, i'm up at bribie.Man the kombi looks sick,my kids saw it and went nuts.
