Aussieveedubbers 路 Tech Talk
Bloody mudflap brackets!
https://forums.aussieveedubbers.com/threads/39368/bloody-mudflap-brackets
ruckus 路
I've got some Empi mudflaps that I want to fit to my 71 standard bug. They didn't come with brackets but I thought "Ah she'll be right, they'll be easy to find!"
Wrong! This is really starting to sh#t me because I don't have the time to fabricate them myself and I thought I'd solved the problem when I bought some brackets from someone only to find they don't even appear to fit the mudflaps I had to buy them with to get them !馃槧
Anyway so what can I do? Is it possible to just buy the right brackets from a shop or something?
[Edited on 18/5/2005 by ruckus]
ruckus 路
:cussing
Adam_C 路
try bunnings, its what costa did 馃槈
68AutoBug 路
I bought the NOS Mud flaps too......
Brackets were too expensive.....
Go to a BIG W store.... or K Mart Maybe etc....
in the Door knobs & hooks etc You will find some 90 degree
Cadmium plated brackets.... just flat steel, but nice & shiney,
there are different sizes... the size I used....
was : 25mm wide approx 3mm thick and each side roughly 255mm long ... bracket is shaped like an "L"
I used a piece of thin aluminium to bolt to the bracket and to bolt to the mud flaps....
Any more info..... just ask....
68AutoBug 路
the piece of sheet metal is 6 inches high and 7 inches wide...
and My flaps are 4 inches from the ground... at the moment...
the car should settle down another inch or so...[i'm hoping]
the smalls screws attaching the mud flaps to the metal were
about 5 or 6mm x 20mm long with a flat washer either side and a spring washer under the nuts....
ruckus 路
Thanks Lee. Big help.
ruckus 路
Turns out I can't put them on because of my exhaust anyway :blush
