anyone got ideas or pics of places to fit an external oil cooler on a early beetle, somewhere with adequate flow but not too noticeable, dont want it hanging off the front bumper or anything. and rather not chop into the body either.
would up near the front beam work with some ducting? any ideas much appreciated
sam
BiX ·
try above the gear box, hanging from the panal above. mine is offset and sloped foward. with threaded rod holding up the rear. works vry well ( i have to cover it in winter to keep the temp up!!)
VWFOOL ·
cool, ive been reading thru previous posts about it and it seems to work well,
Do you really need one? Or do you just 'want' to fit one?
Life is so much easier without one!
[Edited on 25/5/2005 by VWCOOL]
VWFOOL ·
VWCOOL wrote:Do you really need one? Or do you just 'want' to fit one?
its just to be cool like you
hey can u hook me up with some hodjacks mate?
VWFOOL ·
wat about in the arae in front of the front beam angled down?
Dero ·
Thats a fair way for the oil to go aint it? Prolly wouldnt need the cooler by the time the oil gets to the front beam. Though i wouldnt know...
oval TOFU ·
If you had hoodJax, you wouldn't really need a remote oil cooler would you? Are you running a doghaus shroud right now?
[Edited on 26/5/2005 by oval TOFU]
VWFOOL ·
yeh ill be running a 36hp fan with doghouse, for freeway trips i know i will need it.
and i dont thnik thats a long way for the oil to go considering alot of people mout it off the front bumper or front spoiler.
External oil coolers: extra potential for leaks and blown lines, damage from rocks and gutters and speed bumps, 25 feet of high-friction lines means you need bigger oil pump, they reduce oil pressure and they don't work when the car isn't moving... All good! :duh
Yeah I have Hoodjax in stock which will help you on the F3! U2U sent
[Edited on 26/5/2005 by VWCOOL]
Golde60 ·
how about just putting in a bigger cooler (t4) rather than the t1.
there will probably be some debate now about whether this helps at all.
nothing like an argument eh!
anyway, its another option
btw, the hoodjax are a great product.
engine lid up/down/on/off all very easy
installation easy too.
even if i did have to scratch my head for a while, eh glenn!
yeah, the Type 4 cooler is a good idea... with a bit of mucking around (I haven't done it)
On the same subject, I seem to have noticed the later-model 1600-engined cars (70s) have HEAPS more room in front of the fan housing (and a little less room in the cabin behind the rear seat)... or am I seeing things?
VWFOOL ·
from wat ive heard the type 4 cooler in the shroud is not worth doing? correct
Golde60 ·
thats the debate that i was referring to.
many opinions out there.
im not getting involved
VWFOOL ·
hahaha ok, no worries, i think i read in a previous post from jak rizzo that he didnt get any gains out of that, thats all.
oval TOFU ·
I've read that it does help a little with the larger surface area and extra galleries of the T4 cooler. you'll just have to cut'n'shut the doghouse a bit.
oval TOFU ·
oh yeh, and possibly the wider fan (if there's such a thing as a fan thats wider than the 1600 version)
