Does anyone out ther have any stats on the above????
Interested in putting a set of rims from this model onto a Commodore (steelies for racing) and need to work out if the diameter is big enough i.e the hole in the centre of the rim...
Brad
Bug_racer ·
I'm pretty sure the stud pattern is 5x120 I dont think it is worth it . They are 16's as the smallest wheel option
Desert Bug ·
G'day,
VW Transporter stud pattern is 112 PCD
Commodore stud pattern is 120 PCD
Therefore the diameter of the centre hole is somewhat irrelevent as the rims won't fit on the studs.
You would be better looking for some BMW 16s as BMWs are 120 PCD and will fit.
Cheers.
Alex Holzl ·
the new transporter rims also come in 17" stock. But the PCD difference wouldnt be able to be redrilled to make them 120 pcd... maybe weld them up al drill them...
