I have another stupid door question.
How do i remove the front Qaurter window on the door?
It has like little stud rivett type things holding the swingy thing on but theres no screws or anything?
Also there is a metal bar type thing on the inside of the door around the qaurter window anyone know how to get this out as i have the chrome trim stuck in it that i can get out. And it looks like a pain in the butt when it comes time to put the seals and trim back on?
Scott
toplessbug ·
welcome to the wonderful world of t1 doors they are the biggest pain in the arse you will ever find .. to get the 1/4 vent out
pull back the upper glass run channel near the 1/4 vent and there is a screw remove it then inside the door there is a bolt that goes into the vertical bar for the 1/4 vent remove it then remove the window buy first removing the lower rear glass channel, 1 bolt at the bottom, then pull down, then grab the top of the vent window and pull to the rear at the top only as it comes back slide the rest of it up and out it comes from there reassembly is retracing your steps but to replace the scrapers is really difficult as the ones you buy now have shit clips that break as soon as you touch them so you have to take out you original ones and use them
