would a pic 30 carb be ok for a 1600cc twin port
https://forums.aussieveedubbers.com/threads/39914/would-a-pic-30-carb-be-ok-for-a-1600cc-twin-port
seagull ·
or is the a better carbi
Anthiron ·
they had 34 picts on them stock. which has a bigger throat where it meets the manafold so unless u had an adapter plate then a 30 wouldnt fit anyway.
seagull ·
correct > I need a 34 manafold as the one I have must be from a 1500cc ?
seagull ·
I have a pic 34 in the shed
Anthiron wrote:they had 34 picts on them stock. which has a bigger throat where it meets the manafold so unless u had an adapter plate then a 30 wouldnt fit anyway.
My 1600 has a Brazil 30 jobbie with an adapter plate
I know a lot of people that put the 30 Pict on 1600's especially with 009's. Works heaps better.
Yes - you need the adapter plate
seagull ·
can you buy a new pic 30 or 34 and how many $
Hi Neil,
I believe everyone who sells VW parts over here has the New Brosol [Brazillian Solex] for sale....
Like Mick Motors... email Him for a price...
mick @mickmotors.com.au
He has PICT 30 34 .... for sale...
ruckus ·
I had a 30/31 on my 1600. Had a tendency to stall going down hill with in neutral/coming up to traffic lights, but that could have been caused by something else I guess
zjm ·
I have a 30 on my 1640 and it is heaps better yes you do need the adapter plate its heaps better down low and no worse at high rpm and gives much better economy
[Edited on 2/6/2005 by zjm]
And I pulled it off today and fitted a s/h 34 I bought at the wreckers. The adapter plate is... ahhh... interesting. It narrows the throat horribly and cranks the airflow to the side by about 30 degrees. My car now starts and idles beautifully, goes heaps harder above 70km/h... but stumbles aand farts like a drunk from walking pace to about 60 kays... :duh
seagull ·
mmm so what do I do ?
Quoll ·
put it on and see how it goes 😀
for all you folks with a 009 and a pict 34
have a look at this
http://www.aircooledtech.com/34pict3_modification/
I have done it to one but in the end never tried it
Dero ·
Seagull
I got a carbi in the shed, though not sure what it is... ill check when i get home. It basically brand new.
From memory its 34pict... also logic cause I bought it for the 1500 kombi motor but wouldnt fit. Though still need to check.
Joel
[Edited on 3/6/2005 by Dero]
