I have a little issue with my 68 beetle, whats happening is;
I start my car in the morning ok then drive for about 10 min stop the car then if I immediately try and restart the car I don't have enough battery to do so but if I leave if for 10 - 20 min and try again all is ok and the car starts.
I have checked the battery leads/connections and they look ok
I have checked the water level in battery which looks ok
I think its probably the battery but thought I would see if anyone else had some idea before I spend $100 on a new battery.
thanks in advance
GD
EgeWorks 路
It sounds to me like vapour lock in the fuel system rather than a dead battery.
Happens to my car sometimes in hot weather. I was told to stop the problem take off the filler cap and let the pressure out, then try again. Can't say that it worked very well for me though. I just wait for a few more mins and try again馃檪
PurpleT3 路
When you say you don't have enough battery, do you mean that the starter won't turn, or the engine won't fire?
GavD 路
the starter won't turn at all.
VWCOOL 路
Try taking the terminals off the starter motor and cleaning them thoroughly... Sometimes when they are hot (after the car has been running for a while) they can't deliver enough current
