Has anybody ever studied the relative aerodynamics of various Beetles? None of them are much good, but is one significantly better than the other? For instance, would the lower roofline of an Oval win the battle with the wind, or would the curved screen (but bigger front area) of an L-bug be better? Who would know?!
i was told the oval was the best - especially with the laid back head lights and semephores.
I think the worst was a beetle with upright head lights and front indicators on the top of the guards
buzzbug ·
"Beetle aerodynamics"
isn't that an oxymoron?
Lee.
squizy ·
Yeah I agree with Barry, Glenn. I believe the early models with their flatter, more laid back fronts, are more aerodynamic. I remember reading something about this in an old Hot VW or Trends, but can't remember much else. I'll have a search.
Che Castro ·
I have also heard the Ovals are slightly better than the other early models for front profile because of the difference in roof. Although I'd guess it'd be pretty minor.
Yes I think "beetle aerodynamics" is a bit of an oxymoron 🙂 A kombi is different though 🙂 Funny how in the 30's and 40's people thought the beetle design was ingenious because of its aerodynamics??
Starbug ·
what aerodynamics?:P
you would think that the ovals, with their smaller profile and smoother guards/lights would be the most aerodynamic, but the difference would be so very small...
anyone know of a wind-tunnel we could hire out and test this with? hehehehe
pete wood ·
as I understand it, Beetles have a real issue with aerodynamics once you get up close to 100mph. The shape of the body makes the air cling to it as it passes over it and the air lifts it. Guys at bonneville ended up using little wings to stop the cars lifting dangerously over 100mph. I used to notice my 67 beetle get really floaty above 120kmh. 140 was as quick as I ever dared go, it got way to floaty and scarey.
It called the liberati(?) effect...well not that name, but it's an italian name anyway. You can see it by putting the convex side of a spoon near a running tap. If you hold the shaft of the spoon lightly and put the back of the spoon near the stream of water so it is just touching it, you'll find the water pulls the spoon into the stream almost magnetically. It's really strong.
Yes, being shaped like an aeroplane wing, towards 200km/h an Oval body can be a bit ... light... 😉
A mate of mine and Craig's who used to race videoed his hillclimb car at speed on the freeway - at relatively slow speeds (like, 100 kays, if I recall) the rear lifted by more than an inch. The gap between the tyres and the guards made it obvious...
If anybody has some hard-and-fast fact about real-world experiences (eg: old magazone article or whatever - Bonneville would be good!) on drag, stability and lift it would be great :thumb
[Edited on 3/6/2005 by VWCOOL]
DIY-DUB ·
all i know is goin down a highway with cross winds in a stock height super is nasty
56astro ·
pete wood wrote:It called the liberati(?) effect...well not that name, but it's an italian name anyway.
Bernoulli's principle
amazer ·
you could just get a kombi and have no dramas with lift at all, not at any speed 😀
toplessbug ·
how to hot rod vw engines has a large chapter on this subject written by paul lamar who was the aerodynamacist for jim halls chapparal race team and aerodynamic consultant to american institute of aerodynamicsand astronautics as well as road and track magazine and many more.
he states 75 to 80 mph puts the beetle into high speed regions which are literally unsafe especially on uneven road surfaces or crosswinds ...
stock beetle 1969 weighs 1800 lbs total aero lift at 100 mph is 430 lbs
quote" the vw is probably close to flying as it approaches 100mph,stick to the original design capability 75 mph "
get a copy and read it is very interesting
Warrenm ·
Bizarre wrote:i was told the oval was the best - especially with the laid back head lights and semephores.
The Kombi is more aerodynamic than a Beetle. I posted the research from University /factory research some months ago.
Warren
Found it 20/10/04
I also have camper and bus and at 85-90 get around 10-12 depending on condition.
As for arerodynamics please read the following.
The idea for the Type 2 is credited to Dutch
For other uses of the word Dutch, see Dutch (disambiguation).
. Volkswagen importer Ben Pon, who drew the first sketches of the van in 1947.
Aerodynamics is a branch of fluid dynamics concerned with the study of gas flows. The solution of an aerodynamic problem normally involves calculating for various properties of the flow, such as velocity, pressure, density, and temperature, as a function of space and time. Understanding the flow pattern makes it possible to calculate or approximate the forces and moments acting on bodies in the flow. This mathematical analysis and empirical approximation form the scientific basis for heavier-than-air flight.
The aerodynamics of the first prototypes were not good but heavy optimisation took place at the wind tunnel of the Technical University of Braunschweig
. The wind tunnel work paid off, as the Type 2 was aerodynamically superior to the Beetle despite its slab-sided shape. Three years later, under the direction of Volkswagen's new CEO Heinz Nordhoff, the first production model left the factory at Wolfsburg
:repuke
I'm pretty sure the Kombi has a lower coefficient of drag but the frontal area is much more i'm guessing, so it CdA is probably higher. The Cd of a beetle is 0.38 according to wikipedia http://en.wikipedia.org/wiki/Drag_coefficient, which isn't actually as bad as I thought it would be.
Che Castro ·
actually every other source I have looked at says a beetle is somewhere in the 0.44 range. I think that wikipedia is referring to the NB
I'm very interested in your Cd values. I only ever found one for the beetle = 0.458, and I can't remember where I got that from.
I am quite suprised with the low values for the type 3. I really didn't think it would be anywhere near that low.
When I had my curved windscreen L bug I was sure it was much better than a normal beetle. And my Baja is absolutely shocking, which probably isn't suprising.
If you have a dyno chart for your car, and you find it's top speed on flat ground, then you can back calculate your Cd as well.
Craig Paton ·
My '68 Bug feels fine at 105mph. Straight and true even in the braking area.
amazer ·
Che Castro wrote:actually every other source I have looked at says a beetle is somewhere in the 0.44 range. I think that wikipedia is referring to the NB
[Edited on 3-6-2005 by Che Castro]
I always thought the T2 kombis had a Cd 0.38. I get into a lot of arguments with people when they say aerodynamics of a brick. Well yeah, but better than a F1 car! It all depends on what part of aero you talk about. And of course you always bend the rules to support your own argument.
When I had my kombi in NT doing right back around to 0 kmh it felt absolutely fine. I wouldnt have taken my hands off the wheel, and I wouldnt like to have a road train come the other way, but on its own it drove along very nicely, no fears at all... other than the oil temp.
An early beetle would easily be the slipperiest. Small front screen, smooth bumpers, small wheels, smooth headlights. semaphores or smaller indicators.
edit: not as blunt on the bonnet too
[Edited on 3-6-2005 by amazer]
Hmmmm... I have some research to do!
Warrenm ·
Che Castro wrote:I'm pretty sure the Kombi has a lower coefficient of drag but the frontal area is much more i'm guessing, so it CdA is probably higher. The Cd of a beetle is 0.38 according to wikipedia http://en.wikipedia.org/wiki/Drag_coefficient, which isn't actually as bad as I thought it would be.
The slab side plus the virtual Kamm tail helps a lot
Warrenm ·
Most cars are shaped like an airfoil and have low drag. A well-designed car has a drag coefficient (Cd) between 0.25 and 0.30. Cd is a measurement of drag; the higher the Cd, the greater the drag.
The sloping back end of a VW Beetle gives it more drag than most other cars have. A Beetle's Cd is 0.38.
The wings that Ernest Rogers added to his VW Beetle gave it a blunter back end, making it aerodynamically more like that of other cars. The wings decreased the Beetle's Cd to 0.28.
Anyone know what a Karmann Ghia is? I saw one source that said it was 0.30 and it has a small frontal area.
amazer ·
probably not good as the air would be very turbulent going over all the holes... rusty piles of junk they are 😉
Warrenm wrote:Most cars are shaped like an airfoil and have low drag. A well-designed car has a drag coefficient (Cd) between 0.25 and 0.30. Cd is a measurement of drag; the higher the Cd, the greater the drag.
I thought Cd was the coefficient of drag, not the measure of it...? And which Beetle has a Cd of 38? Oval? 60s? 1500, Super or L? Is that better orworse than the others?
Hopefully my L Bug (1303) with the curved front screen will not be to bad, it will have an areodynamic package, Aero look mudguards, rear tail and 40hp/Porsche style headlights.
The aerodynamic testing in How to Hotrod VW engines is pretty outdated, I say this after having driven beetles very quickly with & without areo dynamic aids.
My new tail style,
56astro ·
They're not parting out the "DAK TO THE FUTURE" are they.
Steve, tell us it's not true.
Ho
No Richard just had the 1st tail out of the mould mounted up on DTTF for me and others to have a look at, I think this tail was sent overseas.
Thew air intakes should solve the problem of getting cool air into the air cleaner intakes
Saw this on Samba & German look, is that some sort of stone deflector on the bonnet?
nbturbo ·
That addition looks to be giving the flat screen Bug similar frontal aerodynamics to an L Bug.Don't know about the big chunks out in front of the driver.I see on the Remmel website he is selling a small deflector that mounts on the roof just above the back window.I have read somewhere that this little thing changes the bad stability issues with Bugs above 120 MPH.Steve,like the look of Richards latest masterpiece-should be good for getting plenty of air into the engine bay.
