Please help, whats the best way to treat surface rust check out the photos.
https://forums.aussieveedubbers.com/threads/40087/please-help-whats-the-best-way-to-treat-surface-rust-check-out-the-photos
wacked1 ·
is sand blasting the best thing, i got some prices for blasting today ranges from $600 - $1800.
or can i use a deoxidiser or is there something out there that i don't even know about.
please explain.
[Edited on 3/6/2005 by wacked1]
A wire brush on a drill...?
36 HORSE ·
Steel wool & Deoxidine will get that light rust off quite easily.
pyr0 ·
what they said ^^^^^
but use a scotch bright pad.
use the steel wool dry (not the soapy type) and rub the wholw thing down then wipe over with dry rag.
the wearing GLOVES apply deoxidiser with a brush, while deoxidser is still wet remove with a sotch bright pad and water.
then dont touch it unless uve got gloves on. (just whack some pressure pack spray paint on it once its dry 😉 )
matt ·
I agree with pyro. As a sandblaster / panelbeater / spray painter the deoxidine method is the easiest way to do it as sandblasting may damage the roof/panels of the car (if the cage doesn't come out)
I am another who will say the deoxidine on a scotch pad will help you out here.
wacked1 ·
sweeet will try deoxidine
matt that cage is part of the chassis
Quincy1874 ·
where do you buy deoxidine from??
Any automotive paint supply shop will have it. It usually comes in 1 litre plastic bottle and has a 'corrosive' symbol on the side of it as it is a phosphoric acid.
Quincy1874 ·
If it's corrosive, wouldn't that do more damage in a few years?
