Wanted - Type III dual carb linkages
https://forums.aussieveedubbers.com/threads/40118/wanted-type-iii-dual-carb-linkages
VWMA Editor ·
Hi Guys,
Looking for the linkages - rods, ends and t-piece - from a Type III dual carb set-up.
Craig
bigbaja ·
i have the rods and i,m sure i have the t peice some where too i,ll dig them out for you
terry
VWMA Editor ·
I'll pop round Monday.
karmen ·
can help if u need with T piece etc
what vintage?
pic if u want.
VWMA Editor ·
I'm actually using them with a single port twin carbie setup on a 1200cc Beetle. Vintage? I don't think it matters, as they're not for a TypeIII application. Yeah pics would be cool.
1500S ·
If you are using them on a beetle you may have to modify the setup to clear fan housing. Have you checked this out?
DH
VWMA Editor ·
Yes, I was speaking with Tim Donovan during the week. Tim was one of the original team mechanics that worked on the first VW factory Rally team in the sixties. To achieve more horsepower, they used the same twin single port setup. On some of the Beetles there was no modifying necessary. On others a small slot or massaged rib was needed in the back of the fan housing. If this modification was needed it did not affect cooling or other clearances.
Mine seems to clear, but I won't know until I have all the linkages in place. Either way, Tim's advice has given me the confidence to continue with this little piece of high(?) performance tuning for my 1200.
