l bug box jumping out of 4th
https://forums.aussieveedubbers.com/threads/40162/l-bug-box-jumping-out-of-4th
kombibob ·
hi all
i have a l bug box in my split, nice smooth box but today it just started to jump out of 4th gear when its under load.
can this be fixed easily or should i start looking for another box?
i have'nt realy done any gearbox work before only motors.
thanks
bob
tdegens ·
Take gearbox to pieces, Get greman autos to grind back the clutch teeth on the fourth gear and put it back in.
Should take about a year if you work at my pace.
phantom ·
I enquired about this recently, as the first decent time I got to drive my buggy it jumped out of 4th twice in a short distance. Advice on here reckoned that there are ways to get around it, or alternatively an expensive fix or replace job.
I enquired with my mechanic about it, apparently an easy but labour-intensive fix......he guesstimated a bill of $700 start to finish...I could have saved a few bucks at the moment as he already has the engine out...but this job will have to wait.
Alternate is to either drive with left hand on stick (slight pressure), keeping the gear in, or to do other things like using an octopus strap to hold it. This is what I'll be trying when I eventually get this thing on the road.
I'll probably be looking for another good box for eventual change, see what happens.
pete wood ·
get it rebuilt properly. It costs, but it will be worth it.
kombibob ·
thanks all
yep i think i will just use a occy strap and save my pennys for a rebuild
and drive the beetle more instead
Adam_C ·
you may be able to tuck the stick behind your leg to get u by.... i did that in my beetle untill the change of gbox
bigbaja ·
its not a l bug box
its a 1500 swing axle beetle box with modified axle tubes
lbugs are irs
i,d just look for a cheap beetle with a good box
or contact v6manx he as a 1500 swinger supposed
to of been built buy german autos
might get it for a couple of hundred
terry
kombibob ·
thanks terry
will do
