baywindow 1/4 vents for sale
https://forums.aussieveedubbers.com/threads/40239/baywindow-14-vents-for-sale
KDFking ·
i have a pair of baywindow opening vents 4 sale,they have the special fittings which let you leave them open while you drive without them shutting(one of the clips is missing though).there is some surface rust on the outer frames,nothing major though and they still need to be cleaned as i dont clean my stuff and the left vent has some scratches on the vertical chrome strip where the special fitting used to rub against while open.if your looking for a set in mint condition then this isnt it(there is an excellent set on ebay aus at the moment though)shipping via sea will cost $45au(sent in 2 parcels)
name andreas
area germany(berlin)
ph# o1633988244(plus county code)
price $155au plus shipping
condition see photos
KDFking ·
another
KDFking ·
another
KDFking ·
last
Andy ·
Sweet,
Never seen those clips before!! They factory extras?
waltermitty ·
mmm I am interested can i see how bad the rust and scratches are?Thanks Mmitchell
Old Dubber ·
I have not seen those clips before either.
However, the way to keep them open is to adjust the tension on the bottom shaft.
Andy ·
Old Dubber wrote:However, the way to keep them open is to adjust the tension on the bottom shaft.
Not too tight though or the shaft comes loose from the opening part of the frame as I discovered on one set!!!
So who's buying the windows?
waltermitty ·
As I said im keen would like a couple of extra shots as per my post. Mitche;ll
KDFking ·
the rust on the bottom of the outer frames does have some pitting but deffinatly no where near thru they just need a little fish oil or a rust converter/protector...and the scatches on the left vent are from the metal tab closing on the corner of the frame(in my opinion they are too deep to be polished out but they could be consealed with a little chrome spray and a small paint brush...)and the vents came of a bay from south africa of all places.the fittings are very practical in my opinion plus they dont look half bad.
KDFking ·
and the scratches....
