dellorto\'s carbies
https://forums.aussieveedubbers.com/threads/4035/dellortos-carbies
sand kombi ·
Will 40mm Dellorto's off a alfa romeo fit a 2ltr motor
what else will I need to make them work ,eg. manifold, linkages etc.it is 2nd hand and unseen as yet
A 2L T4?
you will need T4 manifolds (same as IDF 36,40,44)
Air cleaners
Linkage.
Gaskets
Maybe vents
Definetely jets
They need to be restudded. The Alfa only has 2 studs for the air cleaner so you will need the extra ones put in.
They also have a choke mechanism the needs disconnecting if going on an upright motor cause it interferes with the shroud.
You sure the are DRLA 40's - just unusual
Mostly DRLA 36's or IDF's- still should be ok though
sand kombi ·
thanks heaps for the info. still seems to need a lot to get them going but getting bits slowly it should be to bad
As to the 40mm size thatis just what the ad said,what is the 40mm/36mm ,just the throught width or something else,and is it marked
sand kombi ·
other side
Have you bought these?
Something dont seem right. Are you sure they are not DHLA's ie side draft?
The carbs i have seen have a flat top not a flange at both ends.
Sorry .... it is hard trying to visualise at the office.
The red stuff dont look familiar either
sand kombi ·
I dont know they are on ebay, thought a few people would know alot more about them as I don't know what to look for
BiX ·
They don't look like the 40mm dells I run. Blue mite be rite, sure they are side draught?
Pass on em mate.
You can do better here in Australia.
Give Alfabits a call and see what they have
What state are you in?
