Hey guys,
I recently bought a recoed 1776 engine (new cylinders, barrels etc, recoed standard heads) and I was debating whether or nor to upgrade the camshaft for a bit more pep.
The engine hasnt been run since being rebuilt so I havent experienced how the engine goes currently. However the engine is destined for a new project and I will be putting a decent exhaust as well as twin Weber ICT's, so is it worth splitting the case and putting a better cam in it, or will it go OK with the standard cam? Also, as far as I know the heads are recoed but with standard valves etc, so if I change the cam I may as well change the heads also. Should I leave well enough alone and be hapy enough with the engine, or should I go the extra mile and have more grunt?
I know it's a bit of a vague question, but you guys know what I'm on about (I hope!)
stephenianjames ·
