Name - Brad
Location - Samford
Contact - Email, or Ph 3356 4356 B/H
Item - SIP 170 Dual Purpose Mig Welder.
Desription - As new SIP 170 Copper Transformer welder. This happily welds 5mm plate and has an excellent duty cycle. It has the heavy duty coper transformer which means you can run it flat out for longer and it is much better than the smaller alloy core ones.
Has seen very little work. I bought it to carry around to property to fix gates, shed etc as my bigger welders were to large. Probably used it for about an hour all up.
Excellent condition comes with all factory accesories and a 4.5 kg flux cored wire to get you going.
Price - $500 FIRM
Here are the specs
Migmate Pro 170 Turbo Dual Purpose Mig Welder
SIP's Migmate Portable Mig Welders are a truely superlative and broad range of wire feed welders for enthusiasts and tradesmen alike. These SIP manufactured products and their multiple variants can be found in thousands of homes, garages and workshops world-wide. Unique features, quality, reliability and preformance are combined to produce a very special welding package.
Current Range 25 - 170 amps
Approx weld thickness 0.7 - 7mm (mild steel)
Dual Purpose facility
Copper Wound transformer
Gas/Gasless operation
Professional 40% duty cycle @ 120 amps
Accessories Included
Ready to go in gasless and gas mode
SIP's Migmate range of Portable Mig Welders all go down to an extra low 25 amps which makes them ideal for thin material welding such as car body work
Brad ·
