Aussieveedubbers · VW Circuit Racing
Oran Park Supersprint
https://forums.aussieveedubbers.com/threads/40666/oran-park-supersprint
bigrudi ·
Oran park state round 5 Supersprint championships
3rd of July
Starts 9:30am
bat69 ·
Who went and how did every one go?
Kombi_Rescue ·
wqas it the short circut,what times are they doing in the dubs cheers dsk steve
bigrudi ·
times for my 19 16 lbug 50.05 south circuit 1 min 21 gp
jvl054 ·
Well done Rudi!!!!:thumbJVLRacing
bat69 ·
jvl054 wrote:Well done Rudi!!!!:thumbJVLRacing
When are we going to see that oval sport sedan of yours at some state hillclimbs and super sprints. I saw your dubber at the nationals a few years ago and i've been hanging to see it compete ever since.
Nathan
jvl054 ·
Done a Porsche Sprint round last year.Electrical and Ecu cause some problems.Deffently sorted out some bugs.Money and Renos on houses and a new Business has set me back a bit.Soon I Hope!!!!JVLRacing
bat69 ·
What sort of ecu/electrical problems are you having? Are you running an after market ecu or the standard computer/loom.
71superbug ·
i believe he is running a microtech unit? but wants to upgrade to motec ASAP.
correct me if im wrong 🙂
Anthony
jvl054 ·
Ill will put it this way.....for the hassells ive had,and i was advised to get Motec to start with.....i will not get a cheap bottom of the line ECU again.!!!! JVLRacing
Jak Rizzo ·
Well my cheap bottom of the Line Microtech LTX8s started the engine first go & it hasn't stopped yet! I consider it to be a bargain.
bat69 ·
I ran a motec ecu in my subaru rally car and never had a drama - was happy with it. I have also run microtech on my rotary and never had a drama with it either. I have had other mates run microtech in their rally and drag cars and produce good hp and never have any problems. I thought the mircotech was a good ecu for that application. It sounds like who ever has set it up hasnt done a good job or you just got a lemon.
Jak Rizzo ·
The reason that I chose the Microtech was the fact that most of the modified subies running aftermarket ecu are running the computer that I have. Even the Rigoli's run with the Microtech.
It's also Australian.
regards
Jak
jvl054 ·
Jako Skaiffe Rizzo,The Rigolis boys do use Microtech because they have the facilities to be able to tune them & keep them working....Lots of subies run this ecu because it is cheap and compensates for what you need....Rotarys use them as well because its a sequential Fire System set up.It does not work for me Jako because i run a lower voltage alternator and other componets which the ecu does not compensate for.Some would say...change alternator.That alternator is ther for a reason.My theory is...the motor does not work for the ECU....the ECU works the motor application.
jvl054 ·
Bat69,which computer would you choose,Motec all Microtech?.....Your right! the Ecu wasnt set up right.The Ecu is not the lemon,just wrong application.JVLRacing
I had good success with the Autronic SMC in my yellow car, I will use Autronic in my new car as well.
bat69 ·
jvl054 wrote:Bat69,which computer would you choose,Motec all Microtech?.....Your right! the Ecu wasnt set up right.The Ecu is not the lemon,just wrong application.JVLRacing
From a rallying point of view the motec was great because it allowed for fuel, ignition and boost control along with antilag and rotational idle. A good tool to have in forest racing (antilag). The later two applications as yet are not offered in any mirotech ecu (as far as I know). I liked the motech but it is also worth a sh*t load more. Bang for buck - mirotech.
jvl054 ·
Thanks for your input Bat69,The aim is to race the car with good gear.In Super Tourers we only used Motec and it never failed.I have a ECU deal lined up with all the gear i need.:thumbJVLRacing
