Late Bay Kombi heater fan assy F/S
https://forums.aussieveedubbers.com/threads/40673/late-bay-kombi-heater-fan-assy-fs
I am getting rid of my aircooled spares as the bus is getting Suby motor.
Item - Heater assitance fan and relay. Comes with bracket, and both side tubes (the ones that go on to the heat exchangers. Tubes are near new and the RH tube has the original oval shaped clamp.
No pic sorry, but it definitley works hard and fast.
Name - Peter
Location - Blackburn Vic
Price - $40 ono
Pick up from Blackburn or can make arrangements to drop them off somewhere along places on my way home from work which is in Campbellfield. I come back home through Greensborough way
Contact - u2u or 0403 226 999
waltermitty ·
Peter iss this the fan behind? the dash, If so I need one mine screams when i turn it on, MMitchell.
kombipom ·
You mean the fan isn't supposed to scream? :-)
This is the assist fan on the motor. Helps push more hot air to the front of the bus
Mr Bubble Head ·
If your fan is screaming its proberly because itshitting the sideof the case takeit out and reshape I bet you this will do the trick mine was doing the same on the drivers side
nIck
Still available, make an offer
76camper ·
Where did you get the heater tubes? Went to about 10 shops, no1 had it.... went to a tube shop and he had this other stuff... wanted $180 for a metre of it???? wat a joke.
The tubes on the assist motor were easy to get. So easy I cannot remember where, but no hassle at all.
The first bus we had I got a replacement tube for under the bis in the middle to rplace the original steel rusted tube and that I had to get from Purple Pig and it cost about $100 for 2 metres.
76camper ·
Got a pic of ur tubes? I was thinking about getting some aluminium ducting...
You can see the fan and a bit of one of the tubes in this shot.
Kombi-K ·
U have U2U (I hope..?! - not real sure how it works...)
U2U received. Check top right hand corner of your screen to see that you have received it.
76camper ·
Is that stuff the same as stock? The stock tubes dont fit over my passenger side duct. Where bouts did you get that stuff?!?!?
It was about three years ago and I really can't remember. I might have gotten a VW guy in Clayton to get it for me when I was working that side of town. Volksbaru I think. He ordered it in from somewhere. He may even have got it from VVDS in Sydney as he got a few other bits for me from there.
See my 1800 motor for sale
