Does anyone know what would be involved in converting a Lefthand Drive Split Kombi to Righthand drive??
Graham.
silver ·
A RHD dashboard should be all you need!
steering box??
DoNkEy ·
a drill
HotRodMatt ·
Open in photoshop, flip horizontal. Done.
Just joking...
Is it gonna be a daily? If not why not just keep it a left hook?
vwtyp2 ·
keep it LHD.
under the 30 year rule, you don't have to change it.
VolksFolks ·
speak to RobK aka splitbusaustralia, he has done the conversion..
Andy
bigbaja ·
pitman arm , pedle set, handbrake lever, speedo cable,
lots of patients,
a doner car would be great to see whats going on and how it goes on
57 Chook Shed ·
So the steering box/column can be swapped side to side??
Alex Holzl ·
is it like an oval where the bumps and stuff are on both sides they just need swaping over???
Kombi_Rescue ·
a lhd str box wont fit a rhd conversion,dont forget clutch/acc conduit need tobe relocated along with heater tap mastercylinder location and inspection port etc ..wiring harness needs work also and the gearstick good luck..best witha donor car cheers dsk steve
