wanted: early horn ring screws and springs
https://forums.aussieveedubbers.com/threads/40854/wanted-early-horn-ring-screws-and-springs
Lams ·
Hi guys, does anybody have these parts lying around doing nothing?
I'm after the horn ring screws, springs and those white spacers that would let me get my horn ring working again. I think anything that had a horn ring on the steering wheel would have these parts?
please contact me by U2U if you have these parts. Thanks a lot!
pod ·
try your local vw specialist as only about $12 if that a set and you will have to have the live wire up through the column for it all to workand make sure you have the brass ring under the horn ring as mine didnt and had to make one up at work:o
I am pretty sure Vintage has these new 02-9789-1777 the nylon bits u need new anyway t o insulate
Lams ·
thankyou both
I'll try ringing around. I've got the wire going through the steering column, just need the switch to work properly now...
