Hi has anyone a solution to icing carby causing throttle to stick?Will smaller jets help?I'm running a bug spray and have even put a IMDU from pomgolia on it and its still ahappenen!
thanks
lohoon ·
https://forums.aussieveedubbers.com/threads/40907/carbi-icing-up
lohoon ·
Grey 57 ·
Grey 57 ·
mnsKmobi ·
What are you running the carb on? You can get manifolds for the progressive carb for a Type 1 engine that have the exhaust preheat like the stock manifold. Your options are more limited on the Type 4 (kombi) engine. Basically you can:lohoon wrote:Hi has anyone a solution to icing carby causing throttle to stick?Will smaller jets help?I'm running a bug spray and have even put a IMDU from pomgolia on it and its still ahappenen!
thanks
baby_beetle ·
