Would a 34 pict suit a 1776 or am i better of with a dual throat weber. i'm after a reliable ride not a street weapon.:duh
depends
I have had a 1776 with a DFEV (Progressive) Weber and a 1916 with a 34 pict
Both were good.
I jetted the weber myself and the Pict was done.
Is the dual throat weber progressive (DFEV etc) or non (IDF etc) ???
You going to jet it your self??
jaksc ·
it has a standard cam. the cary is from a 1600 motor and I have no idea whether the weber is progressive or non. how do you tell?
tassupervee ·
Simple
Open the throttle, if one butterfly opens before the other then the carb is progressive.
L8tr
E
jaksc ·
it doesn't seem to be progressive carby. Alli can tell is it is a dual weber with brevettato on one side and bolgna on the other with a high rise manifold. I also have a 34 pict carby. Which would be best suited for reliable transport. The 1776 is balanced with a counterweight crank and standard cam.
cheers Aaron
koolkarmakombi ·
34 pict with svda dizzy.
reliable
drivable
jaksc ·
Would the 34pict have to be rejetted or just as standard
