Bonnet differences and Removing Bonnet handle
https://forums.aussieveedubbers.com/threads/41036/bonnet-differences-and-removing-bonnet-handle
silverbullet ·
I am wanting to put and older style bonnet onto my 69 beetle. Do they fit ??? Obvisually i would have to change the bottom panel and how it latches, not sure about under the windscreen though. Has any one done this mod.
If i am going to go ahead and change the bonnet over i would also like to remove the bonnet handle. What is involved to do this ???nn[ Edited on 1/7/2005 by silverbullet ]
Menangler ·
Yes I did it on my '69 beetle, fits fine, and gets rid of the air box too.
silverbullet ·
what year did you get your bonnet off. Were you happy with the result?
Menangler ·
I used a '64 - '67 bonnet with the raised emblem, fits well up around the windscreen, no worries.
I use an NOS 60's german front beaver and had to make early front bumper mounts inside the spare wheel well, and of cause an early bonnet catch.
Found a pic
[ Edited on 29-6-2005 by Dave Becker ]
silverbullet ·
Thanks for the pic looks cool. Hope mine comes out as well as that. Apart mine shall have holes cut in for the radiator.
WABaja ·
Are Pre 64-67 bonnets much different to that one in your pic and if so, in what way...??
Thanks..
Che Castro ·
AFAIK there in Oz there is the 54 bonnet which has a triangle thing under the emblem bit??, then there is the 55 - 62 bonnets (i think there is a 4 tab and 3 tab versions) all with no plinth then there is 63-67 which have the raised VW plinth thing and no wolfsburg crest above the handle.
Turbo54 ·
Hi, Yeah your correct about the 54 bonnets, They have a triangle shaped piece under the badge on the underneath and if anyone has one please let me know. These are quite hard to find and to find a good one is really hard. I have many later model bonnets that I will sell to you (55-62 four tab) if you are interested.
T54
silverbullet ·
Unsure on how you get the bonnet to fasten with the handle removed. How is this generally done? i would think with a solinoid. Any ideas would be great.
I saw an article in HVWs I think about removing the handle, they just welded the dogs dick bracket straight onto the bottom of the bonnet and then removed the handle, a bit permanent I thought.
h ·
but it does look sweet wif da handle.. anyway where else do you tow the beetle from.. Lol 😂
