SUBI & GEARBOX CONV O BEETLE
https://forums.aussieveedubbers.com/threads/4111/subi-gearbox-conv-o-beetle
doylo ·
HI ALL I am new to this, so wonder if you could help. I have a ej20t,a semi auto independent pan-ball joint, a good 1960 beetle body etc, but not decided on gearbox-maybe a 6rib kombi. All info and help re completed projects etc would be great especially gearbox,adaptors,cooling etc::thumb
Baja Wes ·
If you haven't found my site yet, you should check it out
http://www.offroadvw.net/bajawes/linktoV6.htm
I chose the 6-rib and also decided to use a taller 4th gear set, and a 4-spider diff from a vanagon.
I think the http://www.rodshop.com.au/ sells suby adaptors, http://www.kennedyeng.com in the US sell them but are expensive, John Sherman on the Gold Coast also sells them but they aren't as good a quality as KEP stuff.
reub ·
Tis is the guy I bought my adapter from
http://www.pnc.com.au/~bill/Transmission.html
Bill is quite helpful and doesn't mind a chat if you want to ask questions. He runs frame buggys and has adapter templates for almost anything. My adapter and flywheel set me back $500 from memory.
I would never deal with Ron Hadfield of the rodshop because he is an asshole to be blunt. I called asking for an adapter for the same application and he ask why the f**k would I want to do that and that if I couldn't find an adapter to just give up.
Have a look throught the forums for previous posts that I've made about my car. Also look at http://ricola.co.uk
Mr Hoodjacks ·
reub-revhead wrote:Tis is the guy I bought my adapter from
Rod Hadfield's not an a-hole. He just has a very dry. laconic sense of humour that is hard to pick over the phone. And for that reason he could probably do himself a favour and not try and be funny with customers he's never met...!
reub ·
What ever.........I'll certainly never deal with him. Too much of a LEGEND for his own good.
