I have all this stuff cluttering up my garage. I have put prices on but will listen to any off and are keen to get rid of most of this stuff.I also have the gearstick and the front shift tube $5 for both and a front beam minus disks, calipers and tie-rod ends $50 There is also the rear tortion bars and spring plates $10 I also have most of the interior panels of a microbus but they have paint splashed on themthe other panels are free to whoever comes and gets them (too big to post. I should be able to post the other stuff except for the bumper. I am between Forster and Tarree and sometimes go to Sydney and can take small item with me.
Hallidays Point 0418 692 557 or 65593156
Rear Bumper Straight left bracket include $30
Incitaor stalk in good working order. Symbols worn on arms$30
Headlightls good working order but one surround cracked. the mesh stone gards and rusted. $20
Cheers Nicko[ Edited on 1-7-2005 by nicko ]nn[ Edited on 1-7-2005 by nicko ]nn[ Edited on 1-7-2005 by nicko ]nn[ Edited on 1-7-2005 by nicko ]nn[ Edited on 2-7-2005 by nicko ]nn[ Edited on 6-7-2005 by nicko ]nn[ Edited on 13-7-2005 by nicko ]
nicko ·
Front grill with plastic bit which is good but has yellu paint sprayed on it. $10
Edited on 2-7-2005 by nicko ]nn[ Edited on 3-7-2005 by nicko ]nn[ Edited on 6-7-2005 by nicko ]
nicko ·
washer bottles I have 2 $5 each
Wipers $10 Only one has bladenn[ Edited on 2-7-2005 by nicko ]nn[ Edited on 3-7-2005 by nicko ]
nicko ·
Rearview mirror $10 I have two of these and they both are a bit dirty but will clean up.nn[ Edited on 1-7-2005 by nicko ]nn[ Edited on 2-7-2005 by nicko ]nn[ Edited on 6-7-2005 by nicko ]
nicko ·
shades dirty but in ok condition $5
Light switch, emergency flasher, fan switch $10 each
nicko ·
Spash pan under the front of a bay. Crusty with a few dents but cound be easily knock back into shape
waltermitty ·
Mate the under dash fans are what I want , do they squeel? If they are quiet can I haave them please? And the arm rests,Also do you have reasonable dash vents? and I want a smick floor mat also? Regards Mitchellnn[ Edited on 1-7-2005 by waltermitty ]
BusMad ·
HI Nicko
I'll take the spare wheel cover, the arm rests, the 'microbus' front door vent plastics and the vent plastics that attach to the back seat boards and the tool bag.
Could you bring these along with the chrome strips and bumper rubber?
Cheers Nicko,
Tim.nn[ Edited on 1-7-2005 by BusMad ]
nicko ·
Front windscreen $50
Fixed glass for the passengers rear window (the one with no vents) $20
these items for pick up only
nicko ·
bump
ltonk ·
Do you have the sliding door 1/4 window?
nicko ·
I dont have any rust free frames but I probably have a glass if you need. Which are you after
Nicko
StenGuns ·
Two front doors (complete) and rust free if possible..
nicko ·
Sorry No doors They were rusty and I could not undo all the bolts so they went to the crusher with the body
nicko
nicko ·
bump
nicko ·
bump
nicko ·
bump
nicko ·
I found 2 speedo cables $5 each and a heater cable $5. Also I have the 3 roof mounted grab bars and the grab bar that attaches to the cab divider $10 the lot. I have a sliding door chrome handle and latch front and rear $10.
nicko ·
Fan housing and fan off the back of a 2litre $10
2litre gearbox including clutch, pressure plate and flywheel offers? Box is in Sydney
