motor is beetle v karmen ghia
https://forums.aussieveedubbers.com/threads/41183/motor-is-beetle-v-karmen-ghia
sand kombi ·
What was the difference between the motors in the beetles, kombi's and the karmen ghia's
Just size or more worked top end or the whole motor worked . Maybe designed different. Iam assuming the carby set up was a lot more refined than the rest of the VW range.
May be a better motor drivetrain combination ❗
What was the first and last year they were made
No reason, just wondered
Mike 🤘
Menangler ·
Beetle and Karmann Ghia engines are the same, except for the air cleaner. Early kombi engines were bacically the same too, 1500 Kombi engines from '63 did have a governer fitted under the carb.
sand kombi ·
under the carb or in the dizzy on the rotar button(that's what my 1600 had on it)
Mike 🤘
Menangler ·
1600 twin port Kombi engines had a rotor button goveror usually 4500 rpm, I think some Type 4 engines had them too. 1500 splitty engines had the govenor under the carb.
