Aussieveedubbers 路 Tech Talk
HELP: noisy rear wheel sound (bearings?) on slammed bug
https://forums.aussieveedubbers.com/threads/41194/help-noisy-rear-wheel-sound-bearings-on-slammed-bug
VWFOOL 路
hi there
my swing axle bug has been slammed at the rear and now started to make a whirring sound from the rear wheels u can hear particularly when slowing down, but not from braking. could this be that no oil is getting to the rear wheel bearings coz of massive negative camber? i jacked up the back for an hour b4 driving today and the sound didnt seem to b there for a while but returned.
is there some way to get around this like sealed bearings?
wat damage am i doing if any?
help is much appreciated
sam
Anthiron 路
i also have a strange sort of light grinding sound coming from the rear passenger side. i dont like it馃憥
oval TOFU 路
bump an old thread coz i need to know too...
vw54 路
time to Un Slam
yes lack of OIL will cause this problem
Jack it up and spin the wheel does it still make the noise ???
MikeM 路
just replace the wheel bearing with a sealed unit.
oval TOFU 路
MikeM wrote:just replace the wheel bearing with a sealed unit.
It's that easy? I don't need to worry about the oil from the grearbox/axe ltubes sloshing against the bearing and possibly mixing with the grease in the 'sealed' bearing when i take the occasional hard corner?
(just covering all possibilities here..)
VWFOOL 路
my problem is solved long ago, just loose bolt on the spring plate allowing a bit of movement
hipichic 路
mine is/was rubbing on the inside of the right rear wheel....some bit sticking out of the car is rubbing lightly on it...and when i have adults in the back, it rubs loudly.....but when its just the kids, it barely rubs at all.
Anthiron 路
fixed mine too......i like a happy ending馃檪
